No temperature logging?
Hi
I am still trying to fix common problems after my update to: 0.93.2
The latest thing I noticed is that my temperature during the day stays the same?
I have enabled:
history:
recorder:
# Delete events and states older than 2 weeks
# purge_days: 14
# View all events in a logbook
logbook:
Is there any new settings I need to do in the UI?
Are there errors relating to your database in the log?
Yes strange errors I deleted the DB and restarted HA but same problem - So just for test I rolled back to Mosquitto broker 4.2 and everything is working again?
So I will wait for 4.4 before upgrading…
(4 days fixing things and still don’t have everything working again…)
Have you set up an access control list (ACL)?
No just normal account in the config, should still work
Incorrect.
Read the warning at he top of the page.
Since version 4.1 of the addon, an explicit ACL definition is now required, see these instructions.
