Just recently I started using HA and the possibilities are fantastic. I just received a ESP8266 which I equipped with a temperature/humidity sensor for testing, but I am unable to read data from it. It is running Tasmota and in the console I can read that it connects to the broker and I can read:
23:50:16 MQT: tele/sonoffTest/SENSOR = {“Time”:“2019-05-24T23:50:16”,“AM2301”:{“Temperature”:23.2,“Humidity”:34.6},“TempUnit”:“C”}
This shows that the sensor is working and that it publishes information.
In Home Assistant I have installed Mosquitto broker via the add-ons. The config I use here is:
“logins”: ,
“anonymous”: true,
“quiet_logs”: true,
“customize”: {
“active”: false,
“folder”: “mosquitto”
“certfile”: “fullchain.pem”,
“keyfile”: “privkey.pem”
This is for testing purposes so I don’t need any security/credentials for now.
The log of Mosquitto shows:
1558737193: mosquitto version 1.5.6 starting
1558737193: Config loaded from /etc/mosquitto.conf.
1558737193: |-- *** auth-plug: startup
1558737193: Opening ipv4 listen socket on port 1883.
1558737193: Opening ipv6 listen socket on port 1883.
1558737193: Opening websockets listen socket on port 1884.
1558737193: Warning: Mosquitto should not be run as root/administrator.
1558737193: New connection from 172.30.32.1 on port 1883.
1558737193: New client connected from 172.30.32.1 as mosqsub|22-core-ssh (c1, k60).
1558737193: New connection from 192.168.1.100 on port 1883.
1558737193: New client connected from 192.168.1.100 as mqtt-explorer-0c365cf7 (c1, k60).
1558737200: New connection from 192.168.1.19 on port 1883.
1558737200: New client connected from 192.168.1.19 as 0 (c1, k10).
1558737208: New connection from 192.168.1.103 on port 1883.
1558737208: New client connected from 192.168.1.103 as 1a6a1923-1069-4420-b3fa-f9e469425ec8 (c1, k60).
It could be interesting to know that the IP addresses are:
172.30.32.1 > An SSH instance to the Raspberry Pi running HA.
192.168.2.100 > The desktop I am working on.
192.168.2.19 > ESP8266 device.
192.168.1.103 > Home Assistant
This indicates that there is no problem in connecting to the broker and it also shows that the broker is running.
Via SSH I am connected to the Raspberry Pi. Here I run:
mosquitto_sub -h 192.168.1.103 -v -t “#”
As far as I can tell this works, because I get no error messages. That being said I also don’t get any other messages. Nothing happens. It looks to me like there are no topics published to the broker.
Via my dekstop I am connected to the broker via MQTT Explorer, but here I also see nothing.
My configuration.yaml looks like:
mqtt:
broker: 192.168.2.103
port: 1883
discovery: truelogger:
default: warning
logs:
homeassistant.components.mqtt: debugsensor:
- platform: mqtt
state_topic: “tele/sonoffTest/SENSOR”
unit_of_measurement: “°C”
value_template: “{{ value_json.AM2301.Temperature }}”- platform: mqtt
unit_of_measurement: “%”
value_template: “{{ value_json.AM2301.Humidity }}”- platform: mqtt
value_template: “{{ value_json.Time }}”
In Home Assistant I see that no value is being read from the ESP8266 since there are no values for Temperature, Humidity and Time in History.
When I go in Home Assistant to services and the mqtt.publish service with service data:
“topic”:“home-assistant/switch/1/on”,
“payload”:“Switch is ON”
then I see the following line in the log:
2019-05-25 01:14:32 DEBUG (MainThread) [homeassistant.components.mqtt] Transmitting message on home-assistant/switch/1/on: Switch is ON
There is, however, no other sign that MQTT is working. Also mosquitto_sub and MQTT Explorer remain quiet.
I am unable to find why I am unable to read topics from the broker. It probably is just a beginners mistake, but I cannot find it. Does anyone have a suggestion to solve this issue?
