No url for access
new install, two things are failing upon boot resulting in no ip address to connect to and the {dot}local addresses not to work
tried reinstalling same thing happens, anyone tell me how to fix it
TIA
DHCP turned on?
first few installs (just playing around) was working fine then I moved it to a different switch on my network and this started
now I cannot get a ip address after doingh a fresh install, same happens if I use a different pi
installing the pi os will get a ip address
Have you set a reservation?
I did but then I deleted it
You want your address to be repeatable and predictable. Start with a reservation and go from there.
I have to have a ip adddress to be able to do that
