I am totally new to Home Assistant. I have installed HA on a Raspberry Pi using the image (hassos_rpi3-4.14.img.gz) and this worked fine. I created a user account as ask to do during the setup. I then installed Mosquitto Broker from the Add-in-Store. The Mosquitto documentation says to create a user by go Configuration->Users, but when I go to Configuration I cannot find the User option. I have tried Googling the problem and I have seen people having the same problem but never a solution. The configuration section does have an option called ‘People’ but I am not sure this is same thing.
Please mark my previous post with the Solution tag. It will automatically place a check-mark next to the topic’s title which signals to other users that this topic has an accepted solution.
Hi all,
Apologies to all if I’m missing something really obvious.
I’m in the same position as ernieP14, I’m new to HA and can’t get the User option in Configuration. I have installed Mosquito Broker and I have enabled Advanced Mode within my profile, though I can’t see an update or accept button. I have restarted HA and logged out and back in again, Advance Mode button is still enabled so I assume the command has been accepted but still no joy.
I have Home Assistant version 2021.12.3 running on a Raspberry Pi 3+ with an ethernet connection.
Many thanks in advance for any help or assistance offered.
