I recently migrated from Domoticz to HA.
I have added the DSMR-service and I get the values from electricity. I don’t get any values from the GAS meter (i did get them in domoticz).
Debug information shows that there is a value available:
2022-07-28 17:09:40 DEBUG (MainThread) [dsmr_parser.clients.protocol] connected
2022-07-28 17:09:40 DEBUG (MainThread) [dsmr_parser.clients.protocol] received data: kW)
1-0:41.7.0(00.011kW)
1-0:61.7.0(00.000kW)
1-0:22.7.0(00.000kW)
1-0:42.7.0(00.000kW)
1-0:62.7.0(00.463kW)
0-1:24.1.0(003)
0-1:96.1.0(4730303634303031393436353933323139)
0-1:24.2.1(220728170958S)(002946.31*m3)
The entity “sensor.gas_consumption” is not disabled.
I cannot add it to my Energy display (no entity found) and adding te entity to a room gives “Unkown”.
I run Home Assistant on a Raspberry Pi,
Home Assistant installation:
Home Assistant 2022.9.6
Supervisor 2022.09.1
Operating System 9.0
Frontend-versie: 20220907.2 - latest
It looks like a bug, because in the Dutch specs, it should like like the debug output above.
I hope I gave enough information and looking for a solution for this issue.
I have tried to find a similar case, but couldn’t find a comparing situation.
Thanks for a helping idea.
