No values in InfluxDB
I’m a very Newbie but nevertheless managed to start a couple of integrations successfully. One thing I cannot solve even after reading everything I can find:
Installed Influxdb and followed the guide. Database shows up up with all the fields, but zero values are populated. No suspicious entries in the logs.Restarting does not help
 influxdb:
  host: a0d7b954-influxdb
  port: 8086
  database: homeassistant
  username: homeassistant
  password: password
  ssl: false
  verify_ssl: false
  max_retries: 3
  default_measurement: state
Welcome.
How did you assess that there are no values but “fields”?
  1. InfluxDB->Explore
  2. selected random entity values in homeassistant.autogen DB (i.e.
    C → Netatmo_temperature → value)
    result: no values in upper window and 'query is syntatctically correct but returned no results
solved ! changed config.yaml : host = homeassistant IP-address instead of
a0d7b954-influxdb. Thanks anyway
Cool.
Please mark your post as the solution so that:
  1. People know you don’t need help anymore
  2. People with similar issues know there is a potential solution here.
done thanks. MY first post. appreciate your guidance
Thank you!! I was struggling with the same thing
