No voice feedback from Assist
I setup Piper for TTS but when I run Assist (both on Android companion app and on FF browser) I do not get any voice feedback just text on the screen.
I also tried Google for TTS and still not voice feedback (testing TTS works inside the configuration window).
For piper I see in the log that it is unable to download the model but if I put the same URL in the browser I am able to successfully download the model
INFO:wyoming_piper.download:Downloaded /data/en_US-amy-medium.onnx.json (https://huggingface.co/rhasspy/piper-voices/resolve/v1.0.0/en/en_US/amy/medium/en_US-amy-medium.onnx.json)
INFO:wyoming_piper.download:Downloaded /data/en_US-amy-medium.onnx (https://huggingface.co/rhasspy/piper-voices/resolve/v1.0.0/en/en_US/amy/medium/en_US-amy-medium.onnx)
ERROR:asyncio:Task exception was never retrieved
future: <Task finished name='wyoming event handler' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=ConnectionResetError('Connection lost')>
  File "/usr/local/lib/python3.11/dist-packages/wyoming/server.py", line 41, in run
    if not (await self.handle_event(event)):
  File "/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py", line 39, in handle_event
    await self.write_event(self.wyoming_info_event)
  File "/usr/local/lib/python3.11/dist-packages/wyoming/server.py", line 29, in write_event
    await async_write_event(event, self.writer)
  File "/usr/local/lib/python3.11/dist-packages/wyoming/event.py", line 131, in async_write_event
    await writer.drain()
  File "/usr/lib/python3.11/asyncio/streams.py", line 378, in drain
    await self._protocol._drain_helper()
  File "/usr/lib/python3.11/asyncio/streams.py", line 167, in _drain_helper
    raise ConnectionResetError('Connection lost')
ConnectionResetError: Connection lost
INFO:wyoming_piper.download:Downloaded /data/en_US-lessac-low.onnx (https://huggingface.co/rhasspy/piper-voices/resolve/v1.0.0/en/en_US/lessac/low/en_US-lessac-low.onnx)
INFO:wyoming_piper.download:Downloaded /data/en_US-lessac-low.onnx.json (https://huggingface.co/rhasspy/piper-voices/resolve/v1.0.0/en/en_US/lessac/low/en_US-lessac-low.onnx.json)
INFO:wyoming_piper.download:Downloaded /data/en_US-ryan-medium.onnx.json (https://huggingface.co/rhasspy/piper-voices/resolve/v1.0.0/en/en_US/ryan/medium/en_US-ryan-medium.onnx.json)
INFO:wyoming_piper.download:Downloaded /data/en_US-ryan-medium.onnx (https://huggingface.co/rhasspy/piper-voices/resolve/v1.0.0/en/en_US/ryan/medium/en_US-ryan-medium.onnx)
future: <Task finished name='wyoming event handler' coro=<AsyncEventHandler.run() done, defined at /usr/local/lib/python3.11/dist-packages/wyoming/server.py:31> exception=BrokenPipeError(32, 'Broken pipe')>
  File "/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py", line 48, in handle_event
    return await self._handle_event(event)
  File "/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py", line 114, in _handle_event
  File "/usr/local/lib/python3.11/dist-packages/wyoming_piper/handler.py", line 50, in handle_event
  File "/usr/lib/python3.11/asyncio/streams.py", line 366, in drain
    raise exc
  File "/usr/lib/python3.11/asyncio/selector_events.py", line 1057, in write
    n = self._sock.send(data)
BrokenPipeError: [Errno 32] Broken pipe
I get the same “connection lost” error and spoken responses stop working.
As a work around for whatever is causing this bug, I found restarting Home Assistant seems to help.
Same thing here.
