No way to ge the Android TV integration working
Hi all
I’ve been searching for solution here for few days but it looks like I’m the only one with this issue. It’s fairly simple: I cannot get the AndroidTV integration (setup via GUI) to work with my Chromecast with Google TV.
I made sure to remove the existing configuration (as it was working fine until some weeks ago but I was using the ADB Server add-on) and start from scratch (The only 1 thing I didn’t do yet is to wipe the Google device) via the GUI without specifying any custom configuration, just the wizard default.
It looks like the Chromecast receives the connection (I was prompted to allow the connection from HA IP indeed), the device appears in HA, but the only thing I can do with it is just turning on and off. No states, no input sources, look here:
The only hint I have is what I believe the output of some adb commands I tried to send from HA service androidtv.adb_command
Could you please help me to understand what’s going on ?
It really looks like I’m the only one having this issue…
Same problem here. All adb command works fine but the status always off. -
Update the HA system and it works!
Really? Let me check on my end then :slight_smile:
You were right! It works fine now!
