I need help on that one. I did an upgrade a couple of days ago, rebooted my Rpi3 and now, I can’t connect to WebGUI or SSH.
I was able to setup a private key and connect on port 22222 (https://home-assistant.io/developers/hassio/debugging/) but can’t do much in that. Logs won’t show, hassio command not found, etc. How to debug correctly from the debugging console?
If I put journalctl -f -u resin-supervisor.service, all I get is
– Logs begin at Sun 2017-09-17 13:49:22 UTC. –
