I followed the instructions for installing Hass.io on Raspberry Pi 4 Model B 32bit.
I couldn’t get the Wifi configuration to work, so finally, I plugged the ethernet cable and was able to access the service on http://my_ip:8123.
Later, I configured SSH access to the host (via port 22222) and tried to figure out what is wrong with the wifi access. I can see that the wifi is enabled, but there’s no wlan0 interface available. I’m new to Hassio/OS, maybe someone is facing similar issues or can share some insights?
This is what I see:
# uname -a
Linux hassio 4.19.58-v7l #1 SMP Tue Jul 16 20:31:47 UTC 2019 armv7l Hassio/OS
# cat /etc/issue
Welcome to HassOS
# nmcli radio
WIFI-HW WIFI WWAN-HW WWAN
enabled enabled enabled enabled
# nmcli device status
DEVICE TYPE STATE CONNECTION
eth0 ethernet connected Wired connection 1
docker0 bridge unmanaged --
hassio bridge unmanaged --
veth005d26e ethernet unmanaged --
veth2856c98 ethernet unmanaged --
veth3b99adb ethernet unmanaged --
veth77fc2a7 ethernet unmanaged --
lo loopback unmanaged --
# nmcli con show
NAME UUID TYPE DEVICE
Wired connection 1 70699786-5ce7-3b67-8e0d-e9e4059c673d ethernet eth0
my-network 72111c67-4a5d-4d5c-925e-f8ee26efb3c3 wifi --
# ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq qlen 1000
link/ether dc:a6:32:09:c0:3a brd ff:ff:ff:ff:ff:ff
inet 192.168.3.190/24 brd 192.168.3.255 scope global dynamic eth0
valid_lft 63440sec preferred_lft 63440sec
inet6 fe80::8a63:76eb:e759:a1c5/64 scope link
3: docker0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue
link/ether 02:42:c4:56:7b:a4 brd ff:ff:ff:ff:ff:ff
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
inet6 fe80::42:c4ff:fe56:7ba4/64 scope link
4: hassio: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc noqueue
link/ether 02:42:98:b6:3a:bf brd ff:ff:ff:ff:ff:ff
inet 172.30.32.1/23 brd 172.30.33.255 scope global hassio
inet6 fe80::42:98ff:feb6:3abf/64 scope link
6: veth2856c98@if5: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue master docker0
link/ether 1e:a5:d9:65:89:c7 brd ff:ff:ff:ff:ff:ff
inet6 fe80::1ca5:d9ff:fe65:89c7/64 scope link
8: veth005d26e@if7: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue master hassio
link/ether 1e:5a:ab:21:17:74 brd ff:ff:ff:ff:ff:ff
inet6 fe80::1c5a:abff:fe21:1774/64 scope link
10: veth3b99adb@if9: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue master hassio
link/ether 8e:7b:3c:4b:6c:5f brd ff:ff:ff:ff:ff:ff
inet6 fe80::8c7b:3cff:fe4b:6c5f/64 scope link
12: veth77fc2a7@if11: <BROADCAST,MULTICAST,UP,LOWER_UP,M-DOWN> mtu 1500 qdisc noqueue master hassio
link/ether 0a:71:67:e7:0b:ec brd ff:ff:ff:ff:ff:ff
inet6 fe80::871:67ff:fee7:bec/64 scope link
