No Working duckdnss in HomeAssistant
Good morning, I can’t access HA from outside using duckdnss, port 8123 is open, HA ip is static, I’m running HA on Windows 10, I opened the ports through the firewall with I/O rules, in HA core_duckdns reports info: ok, ip, no changes. Any solution? Or how can I access the home assistant from outside the network? Thank you all.
