Hello all,
I am fairly new to HA (played with it a bit in the past, but nothing more than creating integrations with hue and such).
I have recently (received yesterday) a Zooz 700 Series Z-Wave Plus S2 USB Stick ZST10 700, and got it setup in HA pretty easily. I generated the S0 and S2 security keys, as per the instructions in the ZWaveJS supervisor add-on.
For configuring the ZWaveJS addon, I selected the /dev/serial/by-id/...
entry, instead of the /dev/ttyAMA0
When I configured the ZWaveJS integration, it was able to configure things properly, but I noticed that the Device for the Zooz stick states that it doesn’t have ZWavePlus. Is this expected, even though it is a Zwave plus stick? I have an outdoor outlet switch as well. Here are the two devices listed in the integration
Here is the device info for the zooz stick
It says that it isn’t a Z-Wave Plus device, does this mean that it can’t control Z-Wave Plus devices? It also says there is no security. So I am just confused what exactly this device entry is saying.
My outdoor outlet switch however, does say it is Z-Wave Plus.
I am not sure if this means that the controller is working with Z-Wave plus, but the “device” for the controller is just not showing that.
Additionally, the outlet didn’t give me the option for S2 security, even though it does support it. I have tried re-interviewing the device a few times, but it doesn’t change. I have the keys and everything setup properly (according to the documentation of the supervisor add-on).
If anyone could shed some light on if I am misinterpreting things, or if I am correct in my interpretation, help me fix it, that’d be fantastic.
Thanks in advance.
