You know what I was looking at the DIY Zigbee component and not the ZHA one. Thank you for pointing that out.
However now HA is hanging when I restart it. I can see in the logs that the dependencies installed correctly, my zigbee.db gets created, but HA hangs at “Setup of zha is taking over 10 seconds”
If I comment out the zha: section it starts up immediately
It appears the problem is with the underlying bellows package
bellows -d /dev/ttyUSB1 devices
File "/srv/homeassistant/bin/bellows", line 9, in <module>
load_entry_point('bellows==0.2.7', 'console_scripts', 'bellows')()
File "/srv/homeassistant/lib/python3.4/site-packages/click/core.py", line 722, in __call__
return self.main(*args, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/click/core.py", line 697, in main
rv = self.invoke(ctx)
File "/srv/homeassistant/lib/python3.4/site-packages/click/core.py", line 1066, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/srv/homeassistant/lib/python3.4/site-packages/click/core.py", line 895, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/srv/homeassistant/lib/python3.4/site-packages/click/core.py", line 535, in invoke
return callback(*args, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/click/decorators.py", line 17, in new_func
return f(get_current_context(), *args, **kwargs)
File "/srv/homeassistant/lib/python3.4/site-packages/bellows/cli/application.py", line 56, in devices
app = bellows.zigbee.application.ControllerApplication(ezsp, database)
File "/srv/homeassistant/lib/python3.4/site-packages/bellows/zigbee/application.py", line 28, in __init__
self._dblistener = bellows.zigbee.appdb.PersistingListener(database_file, self)
File "/srv/homeassistant/lib/python3.4/site-packages/bellows/zigbee/appdb.py", line 29, in __init__
detect_types=sqlite3.PARSE_DECLTYPES)
sqlite3.OperationalError: unable to open database file
I had an issue when initially setting up ZHA where I needed to provide the full path to the database file, it wouldn’t accept a relative path or using ~ to specify the home directory.
