Hi All… fairly basic problem. I’ve been running Hass.io for about a month now and have been slowly bringing everything in my house that is able to be controlled by home assistant under one roof.
As I’ve gotten core items setup I am starting to branch out into the nice extras … the first being noaa_tides as I live out by the beach.
I believe my fundamental problem is how am I supposed to install any of these python scripts? Where do the scripts go? How are they executed? Link link to project below for what ever that is worth…
I’ve done a lot of reading regarding how to configure various things and get them running, but I’ve got to me missing something fairly basic on this one… Any help would be appreciated.
Maybe not tour scripts per se, but the sensor.py and init.py files.
When I add the sensor to the configuration.yaml file it will either generate errors or simply doesn’t become an available sensor … hence me conceding that I need to somehow do something with the .py files.
After seeing this, I gave it a try, too. Looked up a nearby tide station ID and added the sensor exactly as above (below some other sensors I already have defined.) I did the “Check Config” and it showed valid.
HA won’t restart. No Lovelace, nothing in the home-assistant.log, just dead until I restore the old (unchanged) configuration.yaml and reboot the R Pi.
I did this a few times, in case I’d made a mistake with spacing or something. No improvement.
I just tried on Hassio 0.91.3, latest. There appears to be a Python module missing in the Docker container. I may be able to troubleshoot more this evening when I get home.
Unable to prepare setup for platform noaa_tides.sensor: Could not install all requirements.
8:51 AM setup.py (ERROR)
Not initializing noaa_tides.sensor because could not install requirement py_noaa==0.3.0
8:51 AM requirements.py (ERROR)
Unable to install package py_noaa==0.3.0: Failed building wheel for pandas Command "/usr/local/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-4p16wnn8/pandas/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-v5g4e3mx/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=" failed with error code 1 in /tmp/pip-install-4p16wnn8/pandas/
8:51 AM util/package.py (ERROR)
Version 1.0 of py_noaa was released last December. Perhaps version 0.3 from last August is no longer available.
It appears that the noaa_tides maintainer needs to get this working with 1.0 or, if it already works, update the requirements.
Are you running Hassio or Home Assistant?
Apparently the container homeassistant in Hassio does not have the gcc compiler needed to install dome of the module dependencies.
