NOAH-mqtt via MQTT no longer works
I have had a NOAH 2000 integrated into my HA for a few months now. I established the connection via MQTT and the noah-mqtt. Everything worked fine until yesterday. Since yesterday I no longer receive any data from NOAH. What have I already tried?
  1. restarted HA
  2. rebuild NOAH addon
  3. uninstalled and reinstalled NOAH Addon
  4. removed the NOAH in the ShinePhone app and set it up again
  5. created a new system in the ShinePhone app and set up the NOAH there
I can see the NOAH in the app and can also customize everything. I can also view all the data on the Growatt website. So the access data is correct.
Does anyone have any more ideas about what I can do?
{"time":"2025-02-18T17:08:34.509015446+01:00","level":"INFO","msg":"set log level","level":"DEBUG"}
{"time":"2025-02-18T17:08:34.509507781+01:00","level":"INFO","msg":"noah-mqtt started","version":"0.0.28","commit":"1b938d958ba9abf1f9ea873842230b155b0ff9b6"}
{"time":"2025-02-18T17:08:34.509699407+01:00","level":"INFO","msg":"running as","username":"root","uid":"0"}
{"time":"2025-02-18T17:08:34.509908824+01:00","level":"INFO","msg":"connecting to mqtt broker","host":"core-mosquitto","port":1883,"clientId":"noah-mqtt","username":"addons"}
{"time":"2025-02-18T17:08:34.51561618+01:00","level":"INFO","msg":"connected to mqtt broker"}
{"time":"2025-02-18T17:08:34.516203015+01:00","level":"INFO","msg":"setting server url","url":"https://server-api.growatt.com"}
{"time":"2025-02-18T17:08:44.690094588+01:00","level":"ERROR","msg":"could not login to growatt account","error":"Post \"https://server-api.growatt.com/newTwoLoginAPIV2.do\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"}
{"time":"2025-02-18T17:08:44.690183255+01:00","level":"ERROR","msg":"PANIC ... waiting 15s to exit ..."}
panic: Post "https://server-api.growatt.com/newTwoLoginAPIV2.do": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
goroutine 36 [running]:
noah-mqtt/internal/misc.Panic({0x3c2ec0, 0x400059a690})
	/home/runner/work/noah-mqtt/noah-mqtt/internal/misc/panic.go:11 +0x98
noah-mqtt/internal/polling.(*Service).Start(0x400009e840)
	/home/runner/work/noah-mqtt/noah-mqtt/internal/polling/service.go:38 +0xdc
main.main.func1({0x3c7a48, 0x40000c0288})
	/home/runner/work/noah-mqtt/noah-mqtt/cmd/noah-mqtt/main.go:54 +0x16c
main.connectMqtt.func1({0x3c7a48, 0x40000c0288})
	/home/runner/work/noah-mqtt/noah-mqtt/cmd/noah-mqtt/main.go:72 +0x84
created by github.com/eclipse/paho%2emqtt%2egolang.(*client).startCommsWorkers in goroutine 21
	/home/runner/go/pkg/mod/github.com/eclipse/[email protected]/client.go:614 +0x5dc
{"time":"2025-02-18T17:09:01.792025784+01:00","level":"INFO","msg":"set log level","level":"DEBUG"}
{"time":"2025-02-18T17:09:01.792524827+01:00","level":"INFO","msg":"noah-mqtt started","version":"0.0.28","commit":"1b938d958ba9abf1f9ea873842230b155b0ff9b6"}
{"time":"2025-02-18T17:09:01.792736287+01:00","level":"INFO","msg":"running as","username":"root","uid":"0"}
{"time":"2025-02-18T17:09:01.792949787+01:00","level":"INFO","msg":"connecting to mqtt broker","host":"core-mosquitto","port":1883,"clientId":"noah-mqtt","username":"addons"}
{"time":"2025-02-18T17:09:01.798375392+01:00","level":"INFO","msg":"connected to mqtt broker"}
{"time":"2025-02-18T17:09:01.798490892+01:00","level":"INFO","msg":"setting server url","url":"https://server-api.growatt.com"}
{"time":"2025-02-18T17:09:11.979062515+01:00","level":"ERROR","msg":"could not login to growatt account","error":"Post \"https://server-api.growatt.com/newTwoLoginAPIV2.do\": context deadline exceeded (Client.Timeout exceeded while awaiting headers)"}
{"time":"2025-02-18T17:09:11.979164599+01:00","level":"ERROR","msg":"PANIC ... waiting 15s to exit ..."}
Install the MQTT Explorer add-on and see what the MQTT messages look like. It may not help but it’s worth knowing what the data looks like.
I have already tried, but I can’t get a connection or an answer either
That should be a clue. Connection to what? You connect the MQTT Explorer to the MQTT broker, then watch the data it handles.
Read the comment on Github I linked to, it’s a known issue with the Growatt API.
If I have understood correctly, there is no solution for this yet, is there? I also contacted Growatt support yesterday because the ShinePhone app no longer works when there is a WLAN connection. According to support, someone in China is currently working on the app, which can have such effects. It could take up to 2 days. My fear was that there is a connection here. However, other users of the NOAH apparently have no connection problems in the HA.
From what I understand from the message on Github, the NOAH-mqtt integration uses the same API as the Shine app, so that would explain why the Shine app also isn’t working and you’d have to wait until it gets fixed.
I don’t know why it would still work for others, could be a geographical thing.
Today everything is working again :slight_smile: and without any changes on my side. The problem with the ShinPhone app in the WLAN has also been solved. Obviously the work in China is finished.
Hello Nero2025, does your Noah integration works with the new updates of the core (8.1) and hassio 16.1?
After an update on my side the integration doesn’t work anymore.
Be careful if you update the machine!
Perhaps there is a solution I don’t know.
Greetings
