I am running ESPHome to get data from my Smartmeter over the Home Assistant API which is then used in the Energy Dashboard. So far this is the code I was using:
esphome:
platform: ESP32
board: esp32-poe
includes:
- ./esphome-dlms-meter
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
power_pin: GPIO12
domain: .lan
# Enable logging
logger:
level: INFO
# tx_buffer_size: 2048 # Only needed when logging large packets
# Enable Home Assistant API if not using MQTT
api:
password: "..."
reboot_timeout: 0s
ota:
password: "..."
#web_server:
# port: 80
uart:
tx_pin: GPIO4
rx_pin: GPIO36
baud_rate: 2400
rx_buffer_size: 1024 # Needed to receive the large packets send by the smart meter
unit_of_measurement: V
accuracy_decimals: 1
device_class: "voltage"
state_class: "measurement"
unit_of_measurement: A
accuracy_decimals: 2
device_class: "current"
unit_of_measurement: W
accuracy_decimals: 0
device_class: "power"
unit_of_measurement: " "
accuracy_decimals: 3
device_class: "power_factor"
unit_of_measurement: Wh
device_class: "energy"
state_class: "total_increasing"
text_sensor:
mqtt:
broker: ''
custom_component:
- lambda: |-
auto dlms_meter = new esphome::espdm::DlmsMeter(id(mbus));
byte key[] = {...};
dlms_meter->set_key(key, 16); // Pass your decryption key and key length here
dlms_meter->set_voltage_sensors(id(meter01_voltage_l1), id(meter01_voltage_l2), id(meter01_voltage_l3)); // Set sensors to use for voltage (optional)
dlms_meter->set_current_sensors(id(meter01_current_l1), id(meter01_current_l2), id(meter01_current_l3)); // Set sensors to use for current (optional)
dlms_meter->set_active_power_sensors(id(meter01_active_power_plus), id(meter01_active_power_minus), id(meter01_power_factor)); // Set sensors to use for active power (optional)
dlms_meter->set_active_energy_sensors(id(meter01_active_energy_plus), id(meter01_active_energy_minus)); // Set sensors to use for active energy (optional)
dlms_meter->set_reactive_energy_sensors(id(meter01_reactive_energy_plus), id(meter01_reactive_energy_minus)); // Set sensors to use for reactive energy (optional)
dlms_meter->set_timestamp_sensor(id(meter01_timestamp)); // Set sensor to use for timestamp (optional)
dlms_meter->set_meternumber_sensor(id(meter01_meternumber)); // Set sensor to use for meterNumber (optional)
dlms_meter->enable_mqtt(id(mqtt_broker), "meter01/data"); // Enable grouped together MQTT report, useful to get exact time with each data for storing results in InfluxDB
return {dlms_meter};
As of 2022.9.2 I get the following error:
[22:48:07][W][mqtt:141]: Couldn't resolve IP address for ''!
[22:48:07][W][mqtt:126]: Error resolving MQTT broker IP address: -16
I have the mqtt configuration part in the code because it is mandatory but I actually don’t need it, as the Home Assistant API is used. What would be the “correct” way to set the MQTT in the configuration so it won’t be used? (I don’t have a MQTT broker and I’m not planning to use one)
I hope this will get my node delivering data again
