Hello
this node here has no FOR… if i switch to “<”
is this a bug?
I need a node that controls a value and if this value is less than 2 for 30 seconds, then a switch is turned off. (between 9:00 and 22:00).
Hello
is this a bug?
It is the same with mine. I can’t say either way if this is normal as I don’t have any current state nodes with that type of condition.
You can use an event state to trigger the flow.
