Hi there!
I’m a professional JavaScript/TypeScript developer, so I’ve set myself the challenge to transfer as many of my automations into TypeScript as I can and I’ve started writing an addon for it.
I’m trying to write a setup that runs on a HA Addon, but hot-reloads ‘plugins’ for my addon. This is something that works locally, using a combination of ts-node and the built in node file watcher.
I’ve got this running on an addon. The addon has the config directory mounted inside the cointainer using
map:
- config:rw
within the config.yaml
file.
I’m then looking for a specific ‘plugins’ directory within the config and creating it if it doesn’t exist. All of this works fine when I run it on my local machine, but for some reason fs.watch()
doesn’t appear to be noticing changes in the mounted plugins directory when I run it on HA. I’m running the latest version of Home Assistant OS on a Raspberry Pi.
Anyone have any thoughts on what is happening here would be much appreciated.
