Hello community,
Any instructions that available to install Node.js on HASSIO.
Hello community,
Your question makes little sense. Hassio is just a couple of docker containers that accept addons that are also docker containers.
There is a HassOS image sometimes confused with Hassio but it is not designed to be extended.
Hassio can be installed on Linux OS that can be extended.
Have a look at https://github.com/helmut-hoffer-von-ankershoffen/hassio-ring-bridge for a Home Assistant -> Ring bridge built as an addon in NodeJS
