Node js socket bind fails with port in use
Hi all!
I am trying to use a node js module in HA Node RED, and I am having troubles with the method used to bind to a socket using dgram implementation.
Here is the code:
try {
            await new Promise((resolve, reject) => {
                socket.on('error', reject);
                socket.on('listening', () => {
                    if (this.#ipAddress.endsWith('.255'))
                        socket.setBroadcast(true);
                    resolve();
                socket.bind(this.#port);
This code bind socket to ‘0.0.0.0:port’, but I get all the time:
Error: bind EADDRINUSE 0.0.0.0:port.
The port is not used at all, I think.
Any help please?
Thank you
OK, It is my app which fails to close the socket from time to time and blow the flow.
I have to review the code a little bit and I will come back here if I have any questions.
It looks like the socket management via the module dgram is not too reliable.
I will be back
