Node MCU - 4 Channel Relay Switch controlled with ESPHome
Hi guys , I couldn’t really find some concrete code on how to flash my Node MCU connected to a 4 channel relay switch currently running on Tasmota so after using integrating various codes off the ESPHome cookbook, here’s some code to help anyone who may be stuck :slight_smile:
esphome:
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key:
ota:
  password:
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip:
    gateway:
    subnet:
  ap:
    ssid: "4-Relay-Switch Fallback Hotspot"
    password:
captive_portal:
binary_sensor:
  - platform: gpio
    pin:
      number: D1
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
  - platform: gpio
    pin:
      number: D2
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
  - platform: gpio
    pin:
      number: D3
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
  - platform: gpio
    pin:
      number: D5
      mode:
        input: true
        pullup: true
      inverted: true
    filters:
      - delayed_on: 10ms
  - platform: status
switch:
  - platform: gpio
    pin:
      number: D1
      inverted: True
  - platform: gpio
    pin:
      number: D2
      inverted: True
  - platform: gpio
    pin:
      number: D3
      inverted: True
  - platform: gpio
    pin:
      number: D5
      inverted: True
You have inputs and outputs defined on the same GPIOs. That won’t work.
Do you have buttons connected to the device? If not get rid of the binary sensors.
Thank you , I do not have buttons , so is the output the switch function and input the binary sensor?
Correct. The switches will show up in Home Assistant.
