I am trying to add two PCF8574 to my NODEMCU AMICA.
I set the two pcf9574 as and changed the jumper accordingly
- id: 'pcf8574_hub_0'
address: 0x20
- id: 'pcf8574_hub_1'
address: 0x21
My code is as follows.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "xxxxxxx"
password: "xxxxxxxx"
power_save_mode: none
manual_ip:
static_ip: 192.168.0.29
gateway: 192.168.0.2
subnet: 255.255.255.0
ap:
ssid: "Node Mcu Pcf9574"
password: "WdS4utI90XHJ"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
i2c:
- id: bus_a
sda: 4
scl: 5
scan: True
# Example configuration entry
pcf8574:
address: 0x20
address: 0x21
binary_sensor:
- platform: gpio
name: "PCF8574 Pin #0"
pin:
pcf8574: pcf8574_hub_0
number: 0
mode: INPUT
inverted: False
- platform: gpio
name: "PCF8574 Pin #1"
pin:
number: 1
mode: INPUT
inverted: False
- platform: gpio
name: "PCF8574 Pin #2"
pin:
number: 2
mode: INPUT
inverted: False
- platform: gpio
name: "PCF8574 Pin #3"
pin:
number: 3
mode: INPUT
inverted: False
- platform: gpio
name: "PCF8574 Pin #4"
pin:
number: 4
mode: INPUT
inverted: False
- platform: gpio
name: "PCF8574 Pin #5"
pin:
number: 5
mode: INPUT
inverted: False
- platform: gpio
name: "PCF8574 Pin #6"
pin:
number: 6
mode: INPUT
inverted: False
- platform: gpio
name: "PCF8574 Pin #7"
pin:
number: 7
mode: INPUT
inverted: False
- platform: gpio
pin:
pcf8574: pcf8574_hub_1
number: 0
mode: INPUT
inverted: False
status_led:
pin:
number: D4
inverted: FALSE
The problem I experiencing is that both PIN 0 give the same output even though both addresses have been correctly identified during scan, see log below.
[11:27:48][C][wifi:415]: WiFi:
[11:27:48][C][wifi:283]: SSID: 'xxxxxxxxx'
[11:27:48][C][wifi:284]: IP Address: 192.168.0.29
[11:27:48][C][wifi:286]: BSSID: xx xx
[11:27:48][C][wifi:287]: Hostname: 'node_mcu_pcf9574'
[11:27:48][C][wifi:291]: Signal strength: -72 dB ▂▄▆█
[11:27:48][C][wifi:295]: Channel: 6
[11:27:48][C][wifi:296]: Subnet: 255.255.255.0
[11:27:48][C][wifi:297]: Gateway: 192.168.0.2
[11:27:48][C][wifi:298]: DNS1: (IP unset)
[11:27:48][C][wifi:299]: DNS2: (IP unset)
[11:27:48][C][i2c:028]: I2C Bus:
[11:27:48][C][i2c:029]: SDA Pin: GPIO4
[11:27:48][C][i2c:030]: SCL Pin: GPIO5
[11:27:48][C][i2c:031]: Frequency: 50000 Hz
[11:27:48][I][i2c:033]: Scanning i2c bus for active devices...
[11:27:48][I][i2c:040]: Found i2c device at address 0x20
[11:27:48][I][i2c:040]: Found i2c device at address 0x21
[11:27:48][C][pcf8574:021]: PCF8574:
[11:27:48][C][pcf8574:022]: Address: 0x20
[11:27:48][C][pcf8574:023]: Is PCF8575: NO
[11:27:48][C][pcf8574:022]: Address: 0x21
[11:27:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'PCF8574 Pin #0'
[11:27:48][C][gpio.binary_sensor:016]: Pin: GPIO0 (Mode: INPUT)
[11:27:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'PCF8574 Pin #1'
[11:27:48][C][gpio.binary_sensor:016]: Pin: GPIO1 (Mode: INPUT)
[11:27:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'PCF8574 Pin #2'
[11:27:48][C][gpio.binary_sensor:016]: Pin: GPIO2 (Mode: INPUT)
[11:27:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'PCF8574 Pin #3'
[11:27:48][C][gpio.binary_sensor:016]: Pin: GPIO3 (Mode: INPUT)
[11:27:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'PCF8574 Pin #4'
[11:27:48][C][gpio.binary_sensor:016]: Pin: GPIO4 (Mode: INPUT)
[11:27:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'PCF8574 Pin #5'
[11:27:48][C][gpio.binary_sensor:016]: Pin: GPIO5 (Mode: INPUT)
[11:27:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'PCF8574 Pin #6'
[11:27:48][C][gpio.binary_sensor:016]: Pin: GPIO6 (Mode: INPUT)
[11:27:48][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'PCF8574 Pin #7'
[11:27:48][C][gpio.binary_sensor:016]: Pin: GPIO7 (Mode: INPUT)
[11:27:48][C][logger:175]: Logger:
[11:27:48][C][logger:176]: Level: DEBUG
[11:27:48][C][logger:177]: Log Baud Rate: 115200
[11:27:48][C][logger:178]: Hardware UART: UART0
[11:27:48][C][captive_portal:169]: Captive Portal:
[11:27:48][C][ota:029]: Over-The-Air Updates:
[11:27:48][C][ota:030]: Address: 192.168.0.29:8266
[11:27:48][C][api:095]: API Server:
[11:27:48][C][api:096]: Address: 192.168.0.29:6053
[11:28:46][D][binary_sensor:036]: 'PCF8574 Pin #0': Sending state OFF
[11:28:46][D][binary_sensor:036]: 'PCF8574 Pin #0': Sending state ON
Any ideas if my code is wrong or is there another issue here?
Regards,
