I think I’m going mad, or starting to forget something.
I remember that I could rename zwave nodes and give them ids through Configuration - ZWave - Rename node.
Now I see that it only changes the “Friendly name” of the node.
Is it a breaking change in one of the releases from 0.6x to 0.7x ? Do I have to go over all my configs and adjust it? Is there a way to rename zwave node ids now?
Thanks for your time.
Here’s my old config output for a switch:
entity name - switch.wenzhou_tkb_control_system_tz66d_dual_wall_switch_switch_3
new_entity_id: switch.room_2__light_switch
node_id: 4
value_index: 0
old_entity_id: switch.room_2__light_switch_4_0
value_instance: 1
friendly_name: ROOM 2 - Light Switch
And here’s new:
Entity name - switch.room_2__light_switch
node_id: 4
value_index: 0
value_instance: 1
value_id: 72057594109837312
I also switched from Hassbian on RPi to a Hass.io on Ubuntu NAS. I’m using the same UZB stick as before.
