Hello everyone,
I’m using HA OS 2021.12.10 with Node-Red 10.3.4 on a PC.
Node-Red is configured with direct access port 1880.
I’ve set up http in nodes (post and get), which should be exposed as http://homeassistant:8123/endpoint/devicein and :8123/endpoint/deviceinget respectively.
However, if I access these nodes (via Firefox Plugin Rested), I get a 404 error. If I access the nodes via the direct access port of NR, ie., http://homeassistant:1880/devicein, I have to supply HA user credentials and afterwards, I get the 404 error.
What is wrong?
Thanks for your input.
Micha
