Node-Red access to Homeseer switch/dimmer multi-tap features
Forgive me I’m very much a noob. Is there a way to work with multitap events from HS-WD100+, HS-WD200+, HS-WS200+ dimmers and switches in node red? I have home assistant setup with the new zwavejs module. I would like to execute flows in node red initiated by double, triple, quadrouple tap events on these zwave switches.
I’ve been using the zwave_js_value_notification events. They look like:
  "event_type": "zwave_js_value_notification",
  "event": {
    "domain": "zwave_js",
    "node_id": 69,
    "home_id": 3533148989,
    "endpoint": 0,
    "device_id": "a5341af2d0c15e752a72b99512c0536d",
    "command_class": 91,
    "command_class_name": "Central Scene",
    "label": "Scene 002",
    "property": "scene",
    "property_name": "scene",
    "property_key": "002",
    "property_key_name": "002",
    "value": "KeyPressed2x",
    "value_raw": 3
  "origin": "LOCAL",
  "time_fired": "2021-06-19T17:45:20.890066+00:00",
  "context": {
    "id": "cd248ac48fd34aae3b9f9e00975ccbf5",
    "parent_id": null,
    "user_id": null
Only pain is that you don’t get the entity_id so I ended up using the zwave node_id
