malosaa
(Hector)
1
I have node-red installed and working,
But there is a strange thing going on.
Well, i disabled ssl, because i want it to access local trough http://192.168.1.25:1880
When i do that i get an login-tab and need to login with my homeassistant username and pass…
is there a way to disable this ?
this is the message when i press cancel
401 Authorization Required
nginx
Regards
malosaa
(Hector)
2
Found a solution,
adding this to the config: leave_front_door_open: true
not working, where is this config?
Kizovinh
(Pham Quang Vinh)
4
It is very risk because somebody can access to your node red if they have the url.
I am searching for other solution instead of ‘’‘leave_front_door_open’‘’ set to true.
I tried add user and password to the url but it didnt work for my facebook api webhook setup
