Hi, I’m using Node-Red within Homeassistant for ages now and never had issues.
Just to make clear - all the Flows are running and everything seems to work but suddenly my UI has 3 major bugs.
- I can’t click the inject node. Whenever I hover over it I see the “Move Icon”
- The debug Node isn’t outputting anything (I tripple checked it it is enabled and the debug section is set to “all flows”
- The timestamps, that I used to see under the nodes when they’ve last been triggered dissapeared.
Now I tried what I found online like updating everything, including palette and disabling everything unused there but still no luck.
Important - as soon as I disable the HomeAssistant global server Node, the bugs disappear after a reboot.
The log within homeassistant show normal behaviour. (but aren’t very detailed)
Any ideas?
mathias
