Hello, I’m newbie and have started to learn about Node-RED.
I would like to ask you for advice.
In my scenario are used door sensors. Problem is, not all time is same conditions. Door can be opened or closed. In this case scenario needs to start from different sensor states. How to start scenario after switch state toggles? I found some kind of solution, but it’s not best solution.
Thanks you for your advises.
That image doesn’t say much.
But why do you have an inject as the start?
Why not events state and set the “if state” as on or off.
It has two outputs, one for when if state is true and one for when it’s false.
So one for door open and one for door closed.
Hi, let’s I will try to explain.
First block is for time. @6:00 it turns light in bath room, then I can have some light in my room, to do not wake up my wife turning on light in our bad room.
Then 6 blocks to check state of bath door sensor state and as result to dimm brightens from 100% to 40%(then light do not blind me from morning) when door is toggled.
Then it turns on Light in Living room as well,
Then 6 blocks again looking for door state change and turns it off.
At the end, it’s turns of light in living room when I left house.
Probably I think there is some more better solution to replace 6 blocks for light dimming/turning off with 2 blocks.
1 looks if door sensor are toggled, then change state of light.
Thanks you.
Hi, found how to get code out.
"id": "a2b166a975cf364d",
"type": "inject",
"z": "7e113732a5adef9b",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "00 06 * * 1,2,3,4,5",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payloadType": "date",
"x": 110,
"y": 460,
"wires": [
"f026abc420ff424b"
"id": "f026abc420ff424b",
"type": "api-call-service",
"name": "Bath on",
"server": "319813c2.b572dc",
"version": 3,
"debugenabled": false,
"service_domain": "light",
"service": "turn_on",
"entityId": "light.bath_light",
"data": "{\"entity_id\": \"light.bath_light\", \"brightness_pct\": 100 }",
"dataType": "jsonata",
"mergecontext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 280,
"y": 460,
"wires": [
"6a775095c06cb8e9",
"9006f8a6f5af0d0a"
"id": "6a775095c06cb8e9",
"type": "api-current-state",
"name": "Door O",
"version": 2,
"outputs": 2,
"halt_if": "on",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "binary_sensor.bath_door_contact",
"state_type": "str",
"blockInputOverrides": false,
"property": "payload",
"propertyType": "msg",
"value": "",
"valueType": "entityState"
"property": "data",
"value": "",
"valueType": "entity"
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 300,
"y": 380,
"wires": [
"df6eed156a35e1c8"
"id": "df6eed156a35e1c8",
"type": "ha-wait-until",
"name": "",
"version": 0,
"outputs": 1,
"entityId": "binary_sensor.bath_door_contact",
"entityIdFilterType": "exact",
"property": "state",
"comparator": "is",
"value": "off",
"valueType": "str",
"timeout": 0,
"timeoutType": "num",
"timeoutUnits": "seconds",
"entityLocation": "",
"entityLocationType": "none",
"checkCurrentState": true,
"blockInputOverrides": true,
"x": 460,
"y": 380,
"wires": [
"41cafa8baf34b578"
"id": "9006f8a6f5af0d0a",
"name": "Door С",
"version": 2,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"x": 300,
"y": 540,
"wires": [
"b0842db02093aa90"
"id": "b0842db02093aa90",
"name": "",
"version": 0,
"outputs": 1,
"comparator": "is",
"value": "on",
"valueType": "str",
"timeout": 0,
"x": 460,
"y": 540,
"wires": [
"41cafa8baf34b578"
"id": "41cafa8baf34b578",
"name": "Bath on",
"version": 3,
"data": "{\"entity_id\": \"light.bath_light\", \"brightness_pct\": 30 }",
"mergecontext": "",
"queue": "none",
"x": 480,
"y": 460,
"wires": [
"cbd52677320c1af2"
"id": "cbd52677320c1af2",
"name": "Living Room",
"version": 3,
"entityId": "light.curtain_rgb_cct, light.shelf_rgb_cct, light.zal_svet_na_kukhniu",
"data": "{\t \"brightness_pct\": 100 \t}",
"mergecontext": "",
"queue": "none",
"x": 630,
"y": 460,
"wires": [
"30495567590d972a"
"id": "8815366f2202236e",
"type": "delay",
"name": "",
"pauseType": "delay",
"timeout": "2",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"allowrate": false,
"x": 1450,
"y": 460,
"wires": [
"836b49e3eed6fb57"
"id": "836b49e3eed6fb57",
"version": 3,
"service": "turn_off",
"data": "",
"mergecontext": "",
"queue": "none",
"x": 1610,
"y": 460,
"wires": [
"id": "d28f60df538f3660",
"name": "",
"version": 0,
"outputs": 1,
"comparator": "is",
"value": "off",
"valueType": "str",
"timeout": 0,
"x": 1010,
"y": 460,
"wires": [
"c47a06c110ee221e"
"id": "c47a06c110ee221e",
"name": "Bath off",
"version": 3,
"data": "",
"mergecontext": "",
"queue": "none",
"x": 1150,
"y": 460,
"wires": [
"c43943da9c8dc20d"
"id": "c43943da9c8dc20d",
"name": "",
"version": 0,
"outputs": 1,
"entityId": "binary_sensor.entrance_door_contact",
"comparator": "is",
"value": "on",
"valueType": "str",
"timeout": 0,
"x": 1290,
"y": 460,
"wires": [
"8815366f2202236e"
"id": "30495567590d972a",
"type": "delay",
"name": "",
"timeout": "8",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"allowrate": false,
"x": 790,
"y": 460,
"wires": [
"62b29f465d7cf811",
"487aad4f1647ed64"
"id": "487aad4f1647ed64",
"name": "Door O",
"version": 2,
"outputs": 2,
"halt_if": "on",
"value": "",
"property": "data",
"value": "",
"x": 840,
"y": 380,
"wires": [
"91607b07147ae13e"
"id": "91607b07147ae13e",
"name": "",
"version": 0,
"outputs": 1,
"comparator": "is",
"value": "off",
"valueType": "str",
"timeout": 0,
"x": 980,
"y": 380,
"wires": [
"d28f60df538f3660"
"id": "62b29f465d7cf811",
"name": "Door С",
"version": 2,
"outputs": 2,
"halt_if": "off",
"value": "",
"property": "data",
"value": "",
"x": 840,
"y": 540,
"wires": [
"71b26154eebdbea3"
"id": "71b26154eebdbea3",
"name": "",
"version": 0,
"outputs": 1,
"comparator": "is",
"value": "on",
"valueType": "str",
"timeout": 0,
"x": 980,
"y": 540,
"wires": [
"d28f60df538f3660"
"id": "319813c2.b572dc",
"type": "server",
"name": "Home Assistant",
"version": 1,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true
