I am not sure what I have done wrong here? I struggled with understanding what was needed with "credential_secret": ""
I say a post saying it needs to be a random 27 character code. Which is what I have done but it still isn’t working. Sorry if it really obvious but I am still very new to this.
Thank you in advance
Node Red Config
"log_level": "info",
"credential_secret": "ANdji746hgASotMDh109eibfGpe",
"users": [
"username": "admin",
"password": "REMOVED",
"permissions": "*"
"http_node": {
"http_static": {
"port": 1880,
"ssl": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"require_ssl": true,
"system_packages": [],
"npm_packages": [],
"init_commands": []
Node Red Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0. [s6-init] ensuring user provided files have correct perms...exited 0. [fix-attrs.d] applying ownership & permissions fixes... [fix-attrs.d] done. [cont-init.d] executing container initialization scripts... [cont-init.d] 00-banner.sh: executing... ----------------------------------------------------------- Hass.io Add-on: Node-RED v0.7.0 Flow-based programming for the Internet of Things
System Log
18-10-17 12:33:52 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:33:54 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:33:55 INFO (SyncWorker_19) [hassio.docker.interface] Stop hassioaddons/node-red-armhf Docker application
18-10-17 12:33:56 INFO (SyncWorker_19) [hassio.docker.interface] Clean hassioaddons/node-red-armhf Docker application
18-10-17 12:33:57 INFO (SyncWorker_15) [hassio.docker.addon] Start Docker add-on hassioaddons/node-red-armhf with version v0.7.0
18-10-17 12:34:01 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:34:04 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:34:05 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:34:06 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_nodered
18-10-17 12:34:07 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_nodered
18-10-17 12:34:07 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:34:08 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:36:32 INFO (SyncWorker_3) [hassio.docker.interface] Clean hassioaddons/node-red-armhf Docker application
18-10-17 12:36:35 INFO (SyncWorker_0) [hassio.docker.addon] Start Docker add-on hassioaddons/node-red-armhf with version v0.7.0
18-10-17 12:36:39 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:36:42 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:36:43 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:36:44 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_nodered
18-10-17 12:36:45 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_nodered
18-10-17 12:36:45 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:36:46 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:43:21 INFO (SyncWorker_15) [hassio.docker.interface] Clean hassioaddons/node-red-armhf Docker application
18-10-17 12:43:22 INFO (SyncWorker_15) [hassio.docker.addon] Start Docker add-on hassioaddons/node-red-armhf with version v0.7.0
18-10-17 12:43:26 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:43:28 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:43:29 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:43:30 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_nodered
18-10-17 12:43:31 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_nodered
18-10-17 12:43:32 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:43:33 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:44:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-17 12:44:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-17 12:44:12 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
18-10-17 12:44:18 INFO (SyncWorker_6) [hassio.docker.interface] Clean hassioaddons/node-red-armhf Docker application
18-10-17 12:44:19 INFO (SyncWorker_6) [hassio.docker.addon] Start Docker add-on hassioaddons/node-red-armhf with version v0.7.0
18-10-17 12:44:24 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:44:26 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_nodered
18-10-17 12:44:27 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:44:28 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_nodered
18-10-17 12:44:29 INFO (MainThread) [hassio.api.security] /homeassistant/info access from a0d7b954_nodered
18-10-17 12:44:30 INFO (MainThread) [hassio.api.security] /supervisor/info access from a0d7b954_nodered
18-10-17 12:44:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/services access from core_configurator
18-10-17 12:44:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/events access from core_configurator
18-10-17 12:44:54 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from core_configurator
