Node Red add-on, Deploy Failed
I added a debug node to a flow and when I clicked on Deploy, I got this error message:
Deploy failed: No response from the server.
Restarting the add-on did nothing toward fixing the problem.
I tried to restart all flows and got this error:
Deploy failed: 502 Bad Gateway
I suspect this is because I changed my router and most of the devices got a new IP from DHCP. But that’s the only change in my system, therefore my suspicion.
Any suggestions for fixing this would be appreciated.
Here’s the complete logfile from the add-on, from restart to deploy.
    UDN: 'uuid:Socket-1_0-221635K0101FEE',
    UPC: '123456789',
    macAddress: '6038E05C3F84',
    firmwareVersion: 'WeMo_WW_2.00.11401.PVT-OWRT-SNS',
    iconVersion: '6|49153',
    binaryState: '0',
    new_algo: '1',
    iconList: { icon: [Array] },
    serviceList: { service: [Array] },
    presentationURL: '/pluginpres.html'
Callback URL = http://192.168.1.57:46836/wemoNG/notification
30 Dec 12:59:29 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 12:59:29 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 12:59:40 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 12:59:40 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 12:59:44 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 12:59:44 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 12:59:55 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 12:59:55 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 12:59:59 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 12:59:59 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:00:00 - [info] [alexa-remote-account:4627f780.84a6a8] intialising with the PROXY method and saved data...
30 Dec 13:00:00 - [warn] [alexa-remote-account:4627f780.84a6a8] failed to load routines: "no body"
30 Dec 13:00:10 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:00:10 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:00:14 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:00:14 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:00:25 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:00:25 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:00:29 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:00:29 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:00:40 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:00:40 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:00:44 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:00:44 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:00:55 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:00:55 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:00:59 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:00:59 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
problem with resubscription 412 - Precondition Failed
opts - {
  host: '192.168.1.12',
  port: '49153',
  path: '/upnp/event/basicevent1',
  method: 'SUBSCRIBE',
  headers: {
    SID: 'uuid:b394dc16-1dd1-11b2-9d20-e722c1e71656',
    TIMEOUT: 'Second-300'
dev - {
  ip: '192.168.1.12',
  port: '49153',
  name: 'Workshop light ',
  type: 'socket',
  device: {
    ip: '192.168.1.12',
    port: '49153',
    deviceType: 'urn:Belkin:device:controllee:1',
    friendlyName: 'Workshop light ',
    manufacturer: 'Belkin International Inc.',
    manufacturerURL: 'http://www.belkin.com',
    modelDescription: 'Belkin Plugin Socket 1.0',
    modelName: 'Socket',
    modelNumber: '1.0',
    modelURL: 'http://www.belkin.com/plugin/',
    serialNumber: '221635K0101FEE',
    UPC: '123456789',
    binaryState: '0',
    new_algo: '1',
30 Dec 13:01:10 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:01:10 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:01:14 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:01:14 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:01:25 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:01:25 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:01:29 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:01:29 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:01:40 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:01:40 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:01:44 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:01:44 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:01:55 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:01:55 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:01:59 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:01:59 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
30 Dec 13:02:10 - [info] [ping:Ping Steve] ping - Host '192.168.1.14' process timeout - sending SIGINT
30 Dec 13:02:10 - [info] [ping:Ping Kim] ping - Host '192.168.1.37' process timeout - sending SIGINT
UPDATE
I have been doing some experimenting and tried different browsers and got the same results.
I restarted the host- no change.
When I went to the opera browser, instead of copying the URL from Chrome, I typed it in manually, but using the IP instead of homeassistant.local
This works:
http://192.168.1.57:8123/lovelace-hasp/0
This fails:
http://homeassistant.local:8123/lovelace-hasp/0
They BOTH open my Home Page in Home Assistant, but when I try to deploy, the latter URL fails with the message: Deploy failed: No response from the server. When I change the URL from homeassistant.local to 192.168.1.57 the Node Red deploy works fine.
Where is homeassistant.local defined? It is not in my /etc/hosts file.
It’s an mdns address.
So would that make sense that something Node Red is trying to do is not responding to an MDNS query? As I said, I can deploy when I use the IP address, but not when using the MDNS address.
I am not that familiar with node red.
Then we’re equal as I don’t know much about MDNS.
