After the update I did on Home, Node also had this problem, does anyone know of a solution?
Node-RED LOG
[s6-init] making user provided files available at /var/run/s6/etc…exited 0.
[s6-init] ensuring user provided files have correct perms…exited 0.
[fix-attrs.d] applying ownership & permissions fixes…
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts…
[cont-init.d] 00-banner.sh: executing…Add-on: Node-RED
Flow-based programming for the Internet of ThingsAdd-on version: 2
You are running the latest version of this add-on.
System: Home Assistant OS 10.0 (amd64 / generic-x86-64)
Home Assistant Core: 2023.4.5
Home Assistant Supervisor: 2023.04.0Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing…
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] customizations.sh: executing…
[cont-init.d] customizations.sh: exited 0.
[cont-init.d] nginx.sh: executing…
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing…
patch: **** out of memory
[cont-init.d] node-red.sh: exited 2.
[cont-finish.d] executing container finish scripts…
[cont-finish.d] 99-message.sh: executing…Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
