Greetings…
I just updated my Node-Red Addon in Home Assistant to 14.5.0 (Latest update prompt as of 10/2/23). The change log states: “Ships with Node-RED v3.1”.
The error references Node-Red 4.0, which I find interesting because both the Home Assistant Addon and the Node-Red hamburger dropdown in the right hand corner both state version 3.1. So I don’t quite understand the Deprecated API reference to v4.0.
The error does reference node-red-contrib-home-assistant-websocket. If this is related to the Home Assistant Websocket, what is the reference to the deprecated API in v4.0 requiring a CallBack when I’m not running 4.0 but rather v3.1?
I have also posted this to the Node-Red Discourse Forum.
Thank you all very much
td
"Deprecated API warning: Calls to
RED.util.evaluateJSONataExpression
must include a callback. This will
not be optional in Node-RED 4.0.
Please identify the node from the following
stack and check for an update on npm.
If none is available, please notify the node author."
Error:
at Object.evaluateJSONataExpression (/opt/node_modules/@node-red/util/lib/util.js:775:18)
at JSONataService.evaluate (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/common/services/JSONataService.js:58:39)
at TypedInputService.getValue (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/common/services/TypedInputService.js:58:85)
at EventsAll.getTypedInputValue (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:134:39)
at /opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:138:32
at Array.forEach (<anonymous>)
at EventsAll.setCustomOutputs (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/BaseNode.js:137:20)
at EventsAll.onHaEventsAll (/opt/node_modules/node-red-contrib-home-assistant-websocket/dist/nodes/events-all/controller.js:57:18)
at EventEmitter.<anonymous> (/opt/node_modules/node-red-contrib-home-assistant-websocket/di...
