Node red addon vs independent install
What is the difference between node red addon install vs node red independent install?
The addon lives on the same instance as your HA install, so, sharing resources. Also, you lose some abilities like being able to run NodeRed as root (should you want to utilize things like ports below <1024 (which only a root-type of account can do)).
Also, should the server you are running HA on go down, so does your NodeRed instance.
Plus, you also lose the ability to run some nodes that require OS level components or require OS level compiling. These are typically nodes that interact with some low-level boards/GPIO ports and such. While rare, some people do find the need to use them for specific projects.
Personally, I always run NodeRed on it’s own machine as I do more than just home automation tasks with it.
this is the way i manage home assistant and rhasspy on node red
Node red catch intents from rhasspy and than a switch is directing to the right intent. After doing some staff a message (tts) is returned to the right satellite.
  1. Is this the right way to do it?
  2. My control Lights is a home assistant call service node. What is the right way to add a tts response to this sequence?
