node-red addon won’t start after upgrade to 8.1.1
here is error:
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 8.1.1
You are running the latest version of this add-on.
System: Home Assistant OS 5.11 (amd64 / qemux86-64)
Home Assistant Core: 2021.2.2
Home Assistant Supervisor: 2021.02.6
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] customizations.sh: executing...
[cont-init.d] customizations.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
[10:38:50] INFO: Password is NOT in the Have I Been Pwned database! Nice!
patching file nodes/ui_base.html
Hunk #1 succeeded at 1158 (offset 627 lines).
> [email protected] install /config/node-red/node_modules/grpc
> node-pre-gyp install --fallback-to-build --library=static_library
node-pre-gyp WARN Using request for node-pre-gyp https download
node-pre-gyp WARN Tried to download(404): https://node-precompiled-binaries.grpc.io/grpc/v1.24.2/node-v83-linux-x64-musl.tar.gz
node-pre-gyp WARN Pre-built binaries not found for [email protected] and [email protected] (node-v83 ABI, musl) (falling back to source compile with node-gyp)
gyp ERR! build error
gyp ERR! stack Error: not found: make
gyp ERR! stack at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:13:12)
gyp ERR! stack at F (/usr/lib/node_modules/npm/node_modules/which/which.js:68:19)
gyp ERR! stack at E (/usr/lib/node_modules/npm/node_modules/which/which.js:80:29)
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/which/which.js:89:16
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/index.js:42:5
gyp ERR! stack at /usr/lib/node_modules/npm/node_modules/isexe/mode.js:8:5
gyp ERR! stack at FSReqCallback.oncomplete (fs.js:183:21)
gyp ERR! System Linux 5.4.94
gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--library=static_library" "--module=/config/node-red/node_modules/grpc/src/node/extension_binary/node-v83-linux-x64-musl/grpc_node.node" "--module_name=grpc_node" "--module_path=/config/node-red/node_modules/grpc/src/node/extension_binary/node-v83-linux-x64-musl" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
gyp ERR! cwd /config/node-red/node_modules/grpc
gyp ERR! node -v v14.15.4
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --library=static_library --module=/config/node-red/node_modules/grpc/src/node/extension_binary/node-v83-linux-x64-musl/grpc_node.node --module_name=grpc_node --module_path=/config/node-red/node_modules/grpc/src/node/extension_binary/node-v83-linux-x64-musl --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
node-pre-gyp ERR! stack at ChildProcess.<anonymous> (/config/node-red/node_modules/grpc/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:315:20)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
node-pre-gyp ERR! System Linux 5.4.94
node-pre-gyp ERR! command "/usr/bin/node" "/config/node-red/node_modules/grpc/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build" "--library=static_library"
node-pre-gyp ERR! cwd /config/node-red/node_modules/grpc
node-pre-gyp ERR! node -v v14.15.4
node-pre-gyp ERR! node-pre-gyp -v v0.14.0
node-pre-gyp ERR! not ok
npm WARN [email protected] requires a peer of [email protected] but none is installed. You must install peer dependencies yourself.
npm WARN [email protected] requires a peer of [email protected] || 3 || 4 but none is installed. You must install peer dependencies yourself.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: `node-pre-gyp install --fallback-to-build --library=static_library`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2021-02-11T09_39_53_375Z-debug.log
[10:39:53] FATAL: Failed un-installing conflicting packages
[cont-init.d] node-red.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
Oops! Something went wrong.
We are so sorry, but something went terribly wrong when
starting or running this add-on.
Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
any idea?
