Node Red Addpn not starting
I have a problem with my node red addon. I does not start anymore and i dont know why. Does anyone have a hint? Here the Log:
You are running the latest version of this add-on.
System: Home Assistant OS 11.5 (amd64 / generic-x86-64)
Home Assistant Core: 2024.2.2
Home Assistant Supervisor: 2024.01.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 145 packages in 3s
21 vulnerabilities (5 moderate, 14 high, 2 critical)
To address issues that do not require attention, run:
npm audit fix
To address all issues (including breaking changes), run:
npm audit fix --force
Run npm audit for details.
npm notice
npm notice New minor version of npm available! 10.2.3 → 10.4.0
npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.4.0
npm notice Run npm install -g [email protected] to update!
npm notice
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
[17:23:12] INFO: Starting Node-RED…
s6-rc: info: service legacy-services successfully started
start
node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
19 Feb 17:23:13 - [info]
Welcome to Node-RED
19 Feb 17:23:13 - [info] Node-RED version: v3.1.5
19 Feb 17:23:13 - [info] Node.js version: v18.19.0
19 Feb 17:23:13 - [info] Linux 6.1.74-haos x64 LE
19 Feb 17:23:13 - [info] Loading palette nodes
19 Feb 17:23:14 - [info] Node-RED Contrib Theme Collection version: v3.1.9
19 Feb 17:23:14 - [info] Dashboard version 3.6.2 started at /endpoint/ui
19 Feb 17:23:15 - [info] Settings file : /etc/node-red/config.js
19 Feb 17:23:15 - [info] Context store : ‘default’ [module=memory]
19 Feb 17:23:15 - [info] User directory : /config/
19 Feb 17:23:15 - [warn] Projects disabled : editorTheme.projects.enabled=false
19 Feb 17:23:15 - [info] Flows file : /config/flows.json
19 Feb 17:23:15 - [info] Server now running at http://127.0.0.1:46836/
19 Feb 17:23:15 - [info] Starting flows
19 Feb 17:23:15 - [info] Started flows
[17:23:15] INFO: Starting NGinx…
19 Feb 17:23:17 - [error] [api-call-service:45e04beedca3e891] NoConnectionError
19 Feb 17:23:17 - [error] [api-current-state:4adb80e.556bf8] InputError: Entity could not be found in cache for entityId: input_boolean.poolcontrol
19 Feb 17:23:17 - [error] [api-current-state:Prüfung Regen] InputError: Entity could not be found in cache for entityId: weather.home
19 Feb 17:23:18 - [red] Uncaught Exception:
19 Feb 17:23:18 - [error] Error: Huejay: connect EHOSTUNREACH 192.168.1.117:80
at /config/node_modules/huejay/lib/Transport.js:106:15
at processTicksAndRejections (node:internal/process/task_queues:95:5)
[17:23:18] INFO: Service Node-RED exited with code 1 (by signal 0)
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
[17:23:18] INFO: Service NGINX exited with code 0 (by signal 0)
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Supervisor:
24-02-19 17:24:55 WARNING (MainThread) [supervisor.addons.options] Option ‘dark_mode’ does not exist in the schema for Node-RED (a0d7b954_nodered)
24-02-19 17:24:55 WARNING (MainThread) [supervisor.addons.options] Option ‘require_ssl’ does not exist in the schema for Node-RED (a0d7b954_nodered)
24-02-19 17:25:06 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Node-RED is failed, restarting…
24-02-19 17:25:06 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_a0d7b954_nodered application
24-02-19 17:25:06 WARNING (MainThread) [supervisor.addons.options] Option ‘dark_mode’ does not exist in the schema for Node-RED (a0d7b954_nodered)
24-02-19 17:25:06 WARNING (MainThread) [supervisor.addons.options] Option ‘require_ssl’ does not exist in the schema for Node-RED (a0d7b954_nodered)
24-02-19 17:25:06 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on Package node-red/amd64 · GitHub with version
Do you use hue nodes? It looks like they are crashing NR. Start in safe mode, look on the config page of the addon. Then disable the hue nodes then take it out of safe mode.
Thanks, i did not knew that there is a safe mode. After reconfigure the hue node with the new ip node red start again.
