Hi All,
Starting to use Node-RED so could well just be simple lack of knowledge on my side. Trying to use https://alexa-node-red.bm.hardill.me.uk/docs so I can ask Alexa what is the temperature in a room and then get the response back to Alexa.
I set up the initial alexa-home and then used a current-state on a sensor, then linked that to the alexa-home-resp. This appears and is connected but the current-state node is shows a red stop icon under it. I cannot see where i should set “GetTemperatureReadingRequest”.
All I have done with current-state is name the entity i want to read from, can anyone point me in direction of a working flow for this process.
Many thanks
