Theres a button in my childs room. I had it setup that when the button is pressed, it toggles 3 things in her room. Problem is sometimes there’s a hiccup and maybe only 2 things toggle. So now 2 are ON, 1 is OFF. She presses it again, now 2 are OFF, 1 is ON. Now I have the manually change state of the 1 thing in order to get it all back in sync again.
So I changed the flow and added an input boolean that is turned OFF or ON. And the devices are all then set to turn OFF or ON based on the state of the boolean. So even if above issue happened, she just now needs to press the button 2 more times (1 time to turn them ON again, then one more time to try turning them off).
My question is, is there a built in node red device that can take the place of this boolean logic? So I dont need to create a bunch of helpers in HA?
[{"id":"95ed3ce4125c5d63","type":"tab","label":"Flow 1","disabled":false,"info":"","env":[]},{"id":"5e30d3f8c638f026","type":"server-state-changed","z":"95ed3ce4125c5d63","name":"Button pressed","server":"ab3e2c53.e3491","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.button_em_s_room_action","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"eventData"},{"property":"topic","propertyType":"msg","value":"","valueType":"triggerId"}],"x":410,"y":360,"wires":[["dc71e6003b4eec2d"]]},{"id":"dc71e6003b4eec2d","type":"switch","z":"95ed3ce4125c5d63","name":"One, two or hold","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"single","vt":"str"},{"t":"eq","v":"double","vt":"str"},{"t":"eq","v":"hold","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":605,"y":360,"wires":[["9b26038042660bb6"],[],[]]},{"id":"57984b4e43fddbd9","type":"api-call-service","z":"95ed3ce4125c5d63","name":"Turn off star projector","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.outlet_ems_room_star_projector"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1420,"y":240,"wires":[[]]},{"id":"9f5123e13487a026","type":"api-call-service","z":"95ed3ce4125c5d63","name":"Turn off outlet for Ems lights under bed","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.outlet_ems_room_lights_under_bed"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1475,"y":285,"wires":[[]]},{"id":"b6640e70d20b82fb","type":"api-call-service","z":"95ed3ce4125c5d63","name":"Turn off hatch","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_off","areaId":[],"deviceId":[],"entityId":["switch.ems_hatch_light"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1405,"y":330,"wires":[[]]},{"id":"9b26038042660bb6","type":"delay","z":"95ed3ce4125c5d63","name":"","pauseType":"rate","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"5","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"allowrate":false,"outputs":1,"x":800,"y":360,"wires":[["e9213497b551bc2d"]]},{"id":"e9213497b551bc2d","type":"api-current-state","z":"95ed3ce4125c5d63","name":"Boolean on?","server":"ab3e2c53.e3491","version":3,"outputs":2,"halt_if":"on","halt_if_type":"str","halt_if_compare":"is","entity_id":"input_boolean.ems_room_devices_off","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"},{"property":"data","propertyType":"msg","value":"","valueType":"entity"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":985,"y":360,"wires":[["967a435c42307b52"],["bb041a73f9642a13"]]},{"id":"af532a3f7da5f18f","type":"api-call-service","z":"95ed3ce4125c5d63","name":"Turn on star projector","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.outlet_ems_room_star_projector"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1425,"y":405,"wires":[[]]},{"id":"acfe494ccbc806c6","type":"api-call-service","z":"95ed3ce4125c5d63","name":"Turn on outlet for Ems lights under bed","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.outlet_ems_room_lights_under_bed"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1470,"y":450,"wires":[[]]},{"id":"a1dc640b1c9214bf","type":"api-call-service","z":"95ed3ce4125c5d63","name":"Turn on hatch","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"switch","service":"turn_on","areaId":[],"deviceId":[],"entityId":["switch.ems_hatch_light"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1410,"y":495,"wires":[[]]},{"id":"967a435c42307b52","type":"api-call-service","z":"95ed3ce4125c5d63","name":"Turn off boolean","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_off","areaId":[],"deviceId":[],"entityId":["input_boolean.ems_room_devices_off"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1160,"y":330,"wires":[["57984b4e43fddbd9","9f5123e13487a026","b6640e70d20b82fb"]]},{"id":"bb041a73f9642a13","type":"api-call-service","z":"95ed3ce4125c5d63","name":"Turn on boolean","server":"ab3e2c53.e3491","version":5,"debugenabled":false,"domain":"input_boolean","service":"turn_on","areaId":[],"deviceId":[],"entityId":["input_boolean.ems_room_devices_off"],"data":"","dataType":"jsonata","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","x":1160,"y":375,"wires":[["af532a3f7da5f18f","acfe494ccbc806c6","a1dc640b1c9214bf"]]},{"id":"ab3e2c53.e3491","type":"server","name":"AvilaSmartHome","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
