Node Red and 172.30.32.1
Has anybody come up with a way to get rid of these error messages, I get 20 of them every time i restart hassio. Looks like Node Red is trying to access some unavailable Home Assistant instance outside my network? Why?
19-10-14 14:51:05 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-10-14 14:51:05 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-10-14 14:51:05 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
It has been like this for a while. I’m on 0.100.2 on an Intel NUC/Debian stretch.
Do you have an additional server configured on that address, or with a name that resolves to that address?
Check your configuration nodes (it’s on the little down-arrow menu next to the debug icon)
No, I don’t. My network is 192.168.10.xxx internally and my public one is 84.x.x.x. My Node Red ‘Home Assistant’ configuration node doesn’t specify the ip address. I have checked the ‘I use hass.io’, so there no input field for ip/url. The only other one with an ip address is to my MariaDB server at 192.168.10.yy.
Have you ever imported a flow from someone else? Not sure if this is still an issue, but last time I imported a flow that includes a HA node it also imported the server config. Check your config nodes tab in NR to see if there are any other HA connections in there.
I’ve checked. There’s only one ha connection in Node Red.
You could try to search your flows.json for the IP and see if there’s a node in there somewhere and try to remove it from there. I would make a backup of flows.json though, before you remove anything.
Good idea! But… I searched the whole node-red directory and found nothing.
I suppose it must be some component called by NR that’s doing this
I don’t use hassio, is that a hassio docker network IP address? it comes up very often on a google search, related to Home Assistant.
I was getting this same error and this one fixed it for me, thank you!
