Hello People,
We have our home installed with 8 radiators and tado.
Big room have main thermostat from tado and the 2 radiators in that room a tado valve
Then we have 5 small rooms each with 1 tado valve and 1 big bedroom with 1 tado valve
The problem or heating system from intergas is to powerfull on low setting to only heat 1 room at the time for example 1 small room with 1 valve. We need to open 3 valves in that time.
So my idear is:
Set small room for example to 22 degree
Then 2 other small rooms valves also need to open automatically
But when i close one of these rooms by hitting the set point it need to stay open. When i close the room where i set the temp. It need to close the other rooms to. This also need to work visa versa
Can someone help me out where to start, i am new in node red have some flows working for lights and Google home
