Node red and various integrations
I have a general question about Node Red.
I would like to move to all Zwave but right now I have Zwave, Tuya(migrating to LocalTuya), Zigbee, Kasa TP Link.
I started to set up Node-Red but and installed Mosquitto for MQTT bridge. This will only work for ZWave, right,?
Can home assistant seamlessly share all of its devices with Node-Red, or do I have to set up intrgrations in Node Red to have it be able to see my Zigbee and WiFI devices?
integrations in nodered = nodes. You start with a fixed pallette and you can add more by going to pallette manager and adding them. FOr the most part you should be able to control everything without adding anything.
Though for instant there is a tplink node that lets you change the polling for switches making them much more responsive. It’s usually a case where you need additional functionality, you look for a specialty node.
