Node RED - Aqara mini switch - Hold & Release not working
Good evening,
I have Aqara mini switch wifi integrated via Zigbe2mqtt and after the last update of Node-RED, I found this bug.
Node-RED stopped to detect statuses HOLD and RELEASE for my Aqara mini switch.
Single and Double statuses are working fine.
I checked it via Debug node in Node-RED.
I see that HOLD and RELEASE are visible in the MQTT log.
Home Assitant 2021.1.5
Node-RED v. 8.0.1
Can somebody confirm this problem too?
how does the debug output looks like when you listen the mqtt topic in node-red?
I use The Event State Node for listening in Node-RED.
As I wrote above, suddenly it not able to recognize a state - Hold & Release.
I checked MQTT state output log this way.
Configuration -> Integration -> MQTT -> Devices -> Aqara wireless switch (WXKG11LM) by Xiaomi -> MQTT INFO -> Most recent received messages
I see Hold state in the log … the same for Release state. Both are there.
I do not know how to check the MQTT state in Node-RED directly.
you can use mqtt-in node to see what does the payload look like. if the hold is visible in the mqtt payload, then you can run your automation directly in node-red as a work around.
Thank you for your reply but unfortunately, I have not any MQTT broker available.
MQTT is added via Integrations.
What should I do?
Thank you.
you already have an MQTT broker if you have that integration… click configure and click re-configure. you will see your broker ip address and other information to setup the same in node-red. mine looks like this:
since you are there, you can also listen the topic for debugging purposes.
thank you for your reply.
I have created new MQTT Broker but I did not know how to obtain TOPIC in the Mqtt node.
So I have this solution for other users - how to find TOPIC
https://www.ha-gh.cz/showthread.php?tid=145&pid=337#pid337
TOPIC is your value here:
143350555_341898106870622_4916514882056454078_n
Hope it helps.
