Node red Assist announcement
Hi all,
I’m trying to create a flow in NodeRed that will call an OpenAI command, and then announce that response via a Home Assistant Voice via the Assist Satellite service.
I can call the openAI command fine, and can get the results in to an msg to be used, but no matter what I try I keep getting errors with the action for the assist announce.
Any feedback anyone can provide will be great, I can do announcements via Alexa but I’m wanting to move to the assist satellite.
The error I keep getting is:
HomeAssistantError: must contain at least one of message, media_id.
My flow is
[{"id":"f769d4888c8955ab","type":"api-call-service","z":"e018b158.1ac7","name":"OpenAI","server":"b3a3253e.d12568","version":7,"debugenabled":false,"action":"openai_conversation.generate_content","floorId":[],"areaId":[],"deviceId":[],"entityId":[],"labelId":[],"data":"{\"config_entry\":\"REDACTED\",\"prompt\":\"I'm going to bed, say goodnight and reference that the evening routine has begun in the style of marvin the paranoid android.\"}","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[{"property":"response","propertyType":"msg","value":"","valueType":"results"}],"queue":"none","blockInputOverrides":true,"domain":"openai_conversation","service":"generate_content","x":320,"y":920,"wires":[["204df5df928bc773","a76ebf8c03e20d43"]]},{"id":"a00cf92aa89f7867","type":"inject","z":"e018b158.1ac7","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":920,"wires":[["f769d4888c8955ab"]]},{"id":"204df5df928bc773","type":"debug","z":"e018b158.1ac7","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":500,"y":980,"wires":[]},{"id":"a76ebf8c03e20d43","type":"function","z":"e018b158.1ac7","name":"Message","func":"\nmsg.payload = { data: { \"message\":msg.response.text, \"preannounce\": \"true\"} }\n\nreturn msg;","outputs":1,"timeout":"","noerr":0,"initialize":"","finalize":"","libs":[],"x":500,"y":920,"wires":[["6fbbbaee8e8da141","9b94c2e46945da9f"]]},{"id":"6fbbbaee8e8da141","type":"api-call-service","z":"e018b158.1ac7","name":"","server":"b3a3253e.d12568","version":7,"debugenabled":false,"action":"assist_satellite.announce","floorId":[],"areaId":[],"deviceId":["f40a944556da62a4970fdb9737d331eb"],"entityId":[],"labelId":[],"data":"","dataType":"json","mergeContext":"","mustacheAltTags":false,"outputProperties":[],"queue":"none","blockInputOverrides":true,"domain":"assist_satellite","service":"announce","x":750,"y":920,"wires":[[]]},{"id":"9b94c2e46945da9f","type":"debug","z":"e018b158.1ac7","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":700,"y":880,"wires":[]},{"id":"b3a3253e.d12568","type":"server","name":"Home Assistant","version":5,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":"30","areaSelector":"friendlyName","deviceSelector":"friendlyName","entitySelector":"friendlyName","statusSeparator":"at: ","statusYear":"hidden","statusMonth":"short","statusDay":"numeric","statusHourCycle":"h23","statusTimeFormat":"h:m","enableGlobalContextStore":true}]
You’re trying to pass the data field using input overrides, but the “Block Input Overrides” option is enabled in the action node. Uncheck that option to allow input overrides to work.
