I have installed the add-on and gotten the web ui to load but as the title shows, the auto-complete feature is not working when I double-click, say, the event state node. I am using Hassio in a VM on Virtualbox. I have included a picture to show the exact area (Entity_ID) I am having issues with.
There are no error messages in the logs for this. I checked the settings in the ui and I see that there is some sort of conflict when I try to install a node-red extension for lack of better words. I am wondering if this has anything to do with it.
How is your setup look like. Do you have node red as stand alone on a server and trying to install Home assistant as new pallets? Or did you install node red as an addon to HA?
I installed it as an add-on. I use Hass.io on a VM. The only settings in the config of the add-on that I changed was that of the credential secret and the allow_ssl option from “true” to “false”.
So at the very bottom of this page, right below network configuration, you see log. Does it show any errors? if it doesn’t show anything try to hit refresh.
I think you are on to something because now that I look at the log, there is an error about the client not being able to connect to the websocket api. I am uninstalling node-red and restarting hass.io. I will have to deal with it in the morning as I am going cross-eyed. But I will update this thread in the event I can get it to work or not. I appreciate the help @fxcoolby!
No problem, I had few hiccups getting Node Red to work but once it does, it works very consistently. Just make sure once you get it working to take a snapshot.
I had the same problem. I solved it in the node red by disabling the “protection mode” in the hass.io add-on settings for node-red.
I don’t exactly know what are the consequences of this… But, auto completion worked after that. HTH
GV
So it appears as if everything is working on my end now.
I am wondering if just letting some time pass and get a few updates in for both hassio and node red jogged something. This isn’t really a help I know, but I wanted to update this thread with my status. Thanks all for the help! Especially @fxcoolby!
Yes, I also had to struggle and the thread came handing. I am not too happy to have that huge red warning on my red node app page saying I should NOT disable protection mode though…
Thank everyone!
