So guys that are running your home automation setups via node-red, please post on github, would be really nice to see different things that you guys do with it and take inspiration from that.
It’s already the case except for the screenshots.
Enable projects (if you are using Hass.io in /config/node-red/settings.js set editorTheme: / projects: / enabled: to true) and do not forget to enable the credential encryption.
