i have built a flow in node red and big timer, using tasmota devices, but now would like to integrate it into the HA UI . HA currently by discovery only sees it as a switch , on & off, but what i would like is to have a 3 position switch, that can alter the switch from the HA UI ‘on’ , ‘off’ , ‘auto’ how can i achieve this, im not adept at programming - although found node red intuitive
You could try and input select inside Home Assistant with the options on/off/auto then in Node-Red use a trigger node to send the correct outputs based on the value of the input select to the big timer.
i now have quite a few devices on my input select card in the UI 2 additional questions - as i would now like to extend this - one card for outdoor lights & one for indoor lights
how do i rename the input select card to something more user friendly and can i have two cards set up both using input select
