Node Red, Big Timer configuration
I try to control my window lamp from a Node red flow with a Big timer.
I want that the lamp should turn on at dawn and of at sunrise in the morning and back on at dusk and of at 22.00 in the evening.
When I use the first timer for the morning and the second timer for the evening. The Big timer set the output to on in the middle of the day, which is wrong.
Is it not possible to use the Big timer to control both the morning and the evening time ?
Or do I need two Big timer, one for morning and one for evening?
Clock is 10.43 and the Big timer is on.
