Node Red - BigTimer fires every minute
I have set up a big timer in node red for automation of my garden lights. I also did set up an email notification to receive an report, when lights will be switched on or off. Unfortunately the big timer fires every minute. I thought this will only happen, when I use the connection in the middle. But I used the one on the top, which should fire only, when the defined time / event (sunset) happens. What am I doing wrong?
Show the config section of bigtimer. There is a tickbox to fire every minute.
Thanks for the fast reply. Where can I find it?
It’s the repeat output you have checked
Ah. THX! I will try.
i have the same problem but i switch off “Repeat Output” already.
Every Minutes fire the BigTimer.
I don’t have any other Repeat bevor.
what else could be the problem?
Best regards
Achim
