Node Red broken since today
Hi everyone,
today I updated Home Assistant OS from 9.4 to 9.5, now Node-Red won’t start anymore. I even deleted and re-installed it, but it won’t start with the failure message: Error loading settings file: /etc/node-red/config.js
Any suggestions?
6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 14.0.1
You are running the latest version of this add-on.
System: Home Assistant OS 9.5 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.1.7
Home Assistant Supervisor: 2023.01.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
patching file nodes/ui_base.html
Hunk #1 succeeded at 1164 (offset 633 lines).
s6-rc: info: service init-nginx successfully started
up to date, audited 52 packages in 5s
2 packages are looking for funding
run npm fund for details
found 0 vulnerabilities
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
[20:27:30] INFO: Starting Node-RED…
start
node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
[20:27:34] INFO: Service Node-RED exited with code 0 (by signal 0)
[20:27:34] INFO: Starting Node-RED…
i can no longer access my node red after deploying a modbus server node, now i have a problem. how do i go back?.
Stop nodered and use --safe as init_command. Restart. That should start bordered in safe mode with all flows stopped. U should be able to delete the server node and re-deploy the flow.
