Node red broken this morning
So today i got up, and none of my automation in NR are running - checked Noder Red and its in a restart loop.
Managed to catch this error from the logs:
gyp ERR! stack Error: Command failed: /usr/bin/python3 -c import sys; print "%s.%s.%s" % sys.version_info[:3];
Was working yesterday, and I’ve made no changes to HA or NR in the last few days…
Full entry:
pm ERR! gyp ERR! configure error
npm ERR! gyp ERR! stack Error: Command failed: /usr/bin/python3 -c import sys; print "%s.%s.%s" % sys.version_info[:3];
npm ERR! gyp ERR! stack   File "<string>", line 1
npm ERR! gyp ERR! stack     import sys; print "%s.%s.%s" % sys.version_info[:3];
npm ERR! gyp ERR! stack                       ^
npm ERR! gyp ERR! stack SyntaxError: invalid syntax
npm ERR! gyp ERR! stack     at ChildProcess.exithandler (node:child_process:397:12)
npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:390:28)
npm ERR! gyp ERR! stack     at maybeClose (node:internal/child_process:1064:16)
npm ERR! gyp ERR! stack     at Socket.<anonymous> (node:internal/child_process:450:11)
npm ERR! gyp ERR! stack     at Socket.emit (node:events:390:28)
npm ERR! gyp ERR! stack     at Pipe.<anonymous> (node:net:687:12)
npm ERR! gyp ERR! System Linux 5.10.75
npm ERR! gyp ERR! command "/usr/bin/node" "/opt/node_modules/node-gyp/bin/node-gyp.js" "rebuild" "--verbose" "--libsass_ext=" "--libsass_cflags=" "--libsass_ldflags=" "--libsass_library="
npm ERR! gyp ERR! cwd /opt/node_modules/node-sass
npm ERR! gyp ERR! node -v v16.13.1
npm ERR! gyp ERR! node-gyp -v v3.8.0
npm ERR! gyp ERR! not ok
npm ERR! Build failed with error code: 1
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2021-12-03T09_16_31_051Z-debug.log
[09:16:31] FATAL: Failed to install a specified npm package
[cont-init.d] customizations.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
Any ideas?
a restart of NR or HASSIO?
Nope neither made a difference.
However, I have just fixed it by removing
 build-tools
 make
from NPM packages in the config. something in one of them must have broken
But now I cant update any of my palettes :confused:
Now fixed by adding make back to the npm packages, therefore it must have been build tools which is breaking it
