I have an issue with Node Red.
Looks like the operation succeeded but nothing really happened. The light wasn’t turned on.
Any help will be much appreciated.
The first thing I can see is that the domain and the entity domain do not match. You are asking for the service of light to toggle on a switch entity.
If you need to convert your switch to a light you can use the Light switch integration.
Otherwise change the domain to switch and it should work.
Perfect. it worked. thanks
